I'm getting the T2025 error in my Nastran (Version 16.3.0.97) Linear Static Simulation, but I'm not sure what to do about it. It says these points are the culprit, but how do I find out what they're in relation to?
Solved by John_Holtz. Go to Solution.
CORD2R are coordinate systems. The question is why do coordinate systems with ID 34-37 and 52-62 have coordinates of (0,0,0) to define the three points?
In Inventor Nastran environment, find those coordinate systems at the end of the Model Tree. Can you delete them?
John
The T2025 error in Nastran is caused by singularities in the stiffness matrix, which can be due to zero or near-zero values. To troubleshoot the issue, you can check the points listed in the error message and look for physical features or boundary conditions in your model that correspond to them. You can also try increasing the number of substeps, checking for free nodes, rigid body modes, or duplicate nodes or elements. If none of these steps work, contact Nastran technical support.
