Inventor Nastran does not create mesh for frame made of 8020 extrusions
perillarodmiguel
Observer
perillarodmiguel
Observer
Observer
I'm trying to use Nastran to get the Normal Modes of the following structure:8020.jpgMain_Structure.jpg
But every time I try to generate a mesh, I get an error message that the mesh cannot be generated. I know that the 8020 extrusions have some thin elements, so I tried to use the Shell type idealization. That worked to generate the mesh, but when I click run, I get more error messages:
And when I click run:
Does any one know how to solve this problem?
Thanks.
kacper.suchomski
Hi
In the screenshot you can see that the resolution of the mesh is not matched to the level of detail of the profile.
In my opinion you have several potential solutions:
  1. Simplify profile geometry before analysis.
  2. Check the strength factor of these profiles against steel profiles on the manufacturer's website and analyze the virtual profiles in Inventor Nastran.
  3. Use the durability calculators on the item website.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
