I'm using titanium as materials on the deck and tube (I could use steel or something else, I use this because it's so solid and hard), and on the plate I'm using carbon fiber reinforced plastic (I really wanted to use carbon fiber reinforced with epoxy but i didn't find the component in the inventor library.
I want to know what would be the response of the component in this situation of movement and force, thanks!
Solved by John_Holtz. Go to Solution.
Welcome to the Inventor Nastran forum.
One thing is certain: no part of your model is statically stable, so you will not get a solution by running a static analysis. Why are all three parts of the model statically unstable?
The other problem (which would be minimized or eliminated by removing the gap between the plate and deck) is the separation contact has no maximum activation distance entered. Contact elements are only generated at time zero. If the nodes are farther apart than the maximum activation distance, then no contact elements will be created. I suggest always specifying the maximum activation distance, unless you know what the rules are for the two defaults. (I do not know what the defaults are. 🙁)
John
