Edge selection bug Nastran 2023
sigurd.naess
sigurd.naess
Hi!
I recently installed Nastran 2023 (with latest update)
I am not able to select edges in the mesh control using a selection box (hold mouse click and drag)
I have to select each edge individually (a bit tedious...)
Will this be fixed soon?
Thanks!
Regards
Sigurd
John_Holtz
Autodesk Support
Autodesk Support
Hi @sigurd.naess
It is scheduled to be fixed in version 2023.2 and released sometime in November.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
