Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Projection not working
2 REPLIES 2
846 Views, 2 Replies
The projection tool is not working. I imported the picture i need. The color is set to white. A new paint layer is created and the picture is added to the stencil. The stencil shows up, but when i press the button and drag it to project it onto my project the layer does not dissappear and nothing is "sprayed" onto it.
I use a trail version of mudbox 2016. The project is created in an earlier version (so could it be a compatibility problem?)
2 REPLIES 2
absoluteKelvin
the projection paint doesn't work like Zbrush drag rect. you have to paint on the image to project. Or you can use the flood option in the paint options, which projects the entire image onto your model, just make sure the strength is set to 100 or itll give you wierd results
https://www.artstation.com/kelvintam
waxahachie
I hear your pain... The same thing is happening to me. It must be a bug ..?
I even re installed Mudbox and the same thing occurs.
I have done this a zillion times before - but now it has stopped working
