PROJECTION IN MUDBOX
Greetings for all!
I am new here and have a question.
Everytime when I try to project a Stencil on my mesh (for example, a face) I found the same problem: I choose a colored face, use the brush to project but the texture projected is black, not the one I chosen.
What is that? Hope the images can help..thank you!
Could we see your brush projection settings? Also are you using Ptex or your own Uv'd model?
Now I see!
It was not a bug, simply I was painting on the normal map layer. Just created a diffuse layer and painted on the right layer.
Thanks so much!
