Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
preference folder
5 REPLIES 5
1629 Views, 5 Replies
preference folder
is it possible somehow to have the preferences folder somewhere else than in the my documents folder?
if i change the path to something else, upon restart mudbox creates the folders again in the my documents folder ..
cheers chris
5 REPLIES 5
you will need to change the path in Mudbox Windows>Preferences>Paths
thats what i did, but if i delete the folder from my documents and restart mudbox i get a popup telling me that a settings file was found in a mudbox subdirectory.
and no matter if i choose to use the settings or not a new mudbox folder is create in my documents ..
I've noticed the "paths" problem as well. No matter what you change your paths to, they keep reverting back to mydocuments.
I have mudbox installed on drive C and the path to "Temp" folder points to d:\temp.
Mudbox Preferences clearly show d:\temp as a path but Temp files are still saved in the default location in mydocuments.
At the same time paths for "Data" and "Settings" keep reverting back to default paths (inside Windows>Preferences>Paths window)
Go figure ...
I got tired of chasing it ... so I moved the whole mydocuments folder to drive D
I'm looking for this too.
I don't use "my documents" for anything and don't want to use it for mudbox
searching around I found out how to use environmental variables (win7) to make Maya work for me...
... go into sysem properties, add an environment variable called
MAYA_APP_DIR
and set this to where you want to store your stuff, mines set to
D:\maya
I tried to set one at MUDBOX_APP_DIR
-- but it didn't work.
anyone know the proper name for mudbox?
Fix this Autodesk.  I have:
set MUDBOX_DATA_PATH to D:\dev\mudbox
set MUDBOX_SETTINGS_PATH to D:\dev\mudbox\2014-x64\settings
set MUDBOX_WORKING_FILES_PATH to D:\dev\mudbox\2014-x64\data\Temp
moved all the folders to the correct places
deleted the Mudbox folder in My Documents
It looks correct in the Settings > Paths section and yet...
You STILL recreate the folder in My Documents everytime I start Mudbox (inorder to save the "paths" file).  Sort your sh-- out and get rid of the hardcoded paths.
