Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Pixelated Bump Maps
3 REPLIES 3
2392 Views, 3 Replies
Pixelated Bump Maps
How come my bump maps are pixelated ?
Here is my bump map image, if there is something wrong with it ?
Pixelated Bump Maps
3 REPLIES 3
Laurent.Pallares
Laurent.Pallares
Hi, what subdivision sample are you using?, it would be great if do you add a sample of Mudbox file.
Best regards.
Autodesk logo
Laurent Pallarès
Product Support Specialist
Autodesk, Inc.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Best regards.
Autodesk logo
Laurent Pallarès
Autodesk, Inc.
3dMastermind
3dMastermind
Hi.
I did a quick test and the bump map layer seems to work fine on a default as you can see on the attached image.
It could be that your model is not subdivided enough.
Or the map that you use to make the bump looks unecessarily large,
you should be using the whole texture space for the round emblem and avoid the grey in the map.
-manny
Manny Papamanos
StingRay | MotionBuilder | Maya | Mudbox
Games QA Specialist
Hi.
-manny
Manny Papamanos
Games QA Specialist
in reply to: 3dMastermind
Hi Manny. The problem was as you said, the texture should be using the whole texture space, something I overlooked. When I made the size of the brush extra large the bump map looked fine using the second image in the first post.
If your curious my mesh is 3.5 million polygons.
