Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Mudbox2018 doesn't work well on cintiq pro 16
5 REPLIES 5
651 Views, 5 Replies
 Hi, I'm currently using  Mudbox2018 , But there are some problems with running Autodesk programs on cintiq pro 16. I found that the Mudbox does not work even when the functions of the multi-touch and some of sculpt tools with stylus.(but The mouse functions normally....) I have been trying to figure out these issues for about 2 days(almost 41hours), but I can't find any solutions. (reinstall the drivers, reinstall the mudbox,  ask Wacom support team (they said they assumed it wasn't their problems)etc...)
 Turning on the multi-touch function on or off makes no difference.   Also some sorts of sculpt tools doesn't work on a cintiq with a stylus. 2019-01-24 (1).jpg
 But interestingly if I set the monitor to monitor replication ,not the  extension, all of the sculpt tools work. but the multi-touch function still doesn't work.  If it hadn't been working from the beginning until now,I would give up the multi-touch function or extension monitor , but only once did all the functions work normal, so I can't give up.
If you have any solutions, or if it's just a theory it would be very helpful to me. please I need your advice.
Thank  you all for reading. I'll be looking forward to your advice.
5 REPLIES 5
I have a very similar problem with a Wacom Cintiq pro 24" touch. The touch works terribly and the pen is not recognized.
noggity
Have you tried deleting the contents of your Documents/ Mudbox folder? (If there is anything such as your own presets that you don't want to lose, then back this up somewhere safe while trying this). Mudbox will create a clean set of user files on its next start up. This can solve a lot of niggly issues.
Wayne Robson
Experienced 3D Artist
DashDotSlash
Facebook | Twitter | LinkedIn
in reply to: noggity
Thanks for replying.
I just try that but it didn't work.  Do you know if there are issues reported with Mudbox 2019 and Wacom Cintiq pros?
Thank you.
noggity
I'm not personally aware of any and cant check myself as I don't have a Cintiq Pro 16. I will try to see what i can find out for you. Wayne...
Wayne Robson
DashDotSlash
Thank you so much. By the way, I'm using a Cintiq pro 24" with touch and I have a very similar issue.
