Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Mudbox Painting Problem >:(
17 REPLIES 17
Message 1 of 18
5814 Views, 17 Replies
Hey guys,
When painting or projecting in Mudbox I get these weird pixels that get stretched within small squares in the texture. It's like Mudbox is painting in dozens of small tile squares scattered all over the texture and I end up with some of the squares stretched. ??????
Images speak a thousand words so I have attached a screenshot (AND a FBX file of my model), so you can see for yourself:
http://www.flickr.com/photos/aaronescobar/4639847862/
The Model:
http://www.escobarstudios.com/mudbox_model.zip
And a step-by-step video of how I'm causing it to happen:
http://www.youtube.com/watch?v=PEQszZxweK4
Is my model broken? Are the UVs broken? Or is this a Mudbox bug?
mudbox_model.zip
17 REPLIES 17
Message 2 of 18
Christoph_Schaedl
may i see the uvs and the lowres mesh...
think your lowress is to low and the uvs are bad...
this happens cause mudbox is smoothing the vertex position but not the uvs...
https://linktr.ee/cg_oglu
Message 3 of 18
in reply to: Christoph_Schaedl
Could you simply download the model above and see what's wrong? Everyone says the UVs are bad but I spent hours doing the planar mappings in Maya. How could they be wrong?
thanks
Message 4 of 18
Christoph_Schaedl
as i said before... mudbox is smoothing the vertex position but not the uvs by default...
you could turn on uv smoothing in the mudbox subD prefs...
or create a proper basemesh... with equilateral quads and clean uvs...
or if you only painting a lowpolymesh turn off smooth vertex position in the subD prefs and subdivide your mesh before painting...
to fix your problem above ive done a automatic mapping in maya and its working now perfect in mud..
Message 5 of 18
For the record, automatic mappings did not work for me. Worked for major areas but I still get stretching at small corners :(
Message 6 of 18
rvignone
I believe your UV's need better spacing. As of now when you paint on a UV seam, Mudbox will blur the edge of your paint stroke and if your UV's are to close, that edge blur will overlap a close UV shell. You can set the edge bleed in mudbox to 0 in the Prefs>Paint tab, but it is better to have your UV's laid out properly.
Robert Vignone
http://www.robertvignone.com
Win 7 | I7 @ 3.6ghz | 24GB DDR3| GTX580 |
Message 7 of 18
Christoph_Schaedl
automatic mapping on the lowress or the mesh you uploaded above..?
Message 8 of 18
The mesh I uploaded but with updated automatic mappings.
After some more tests with other models, I realised that there seems to be an association between this bug and models of low poly-count. Another cause for this bug was that with automatic mappings from Maya the individual UV shells were too close to each other and were causing Mudbox's paint bleeding effect to overlap each shell. Bellow is an extracted text from Mudbox's documentation:
"The UVs should be laid out in the 3D modeling or UV editing application so that a 4-6 pixel wide empty region exists along the outside perimeter of each UV shell to account for the necessary edge bleed that automatically occurs when painting.
If the UVs are spaced too close to each other, or are positioned too close to the edge of image borders (UV tile edge) seams and paint artifacts can appear on the model when it is painted."
But now I have another question, how do I automatically space each of the UV shells? Is there a way in Maya?
Message 9 of 18
Christoph_Schaedl
there is a layout feature with spacing in maya...
and you could also adjust the spacing value in the automatic mapping settings...
Message 10 of 18
Hi everyone
sorry for tha bad english
i have made various models , spaced the uv's with care automatically and manualy
setting up at best the brushes overlapping and all but the problem stand still sometimes.
WHY???
See the file to judge the spacing and the overlap..
<a href="http://s1080.photobucket.com/albums/j338/mastroprimo/?action=view&current=mudboxtexturespaintingprob... target="_blank"><img src="http://i1080.photobucket.com/albums/j338/mastroprimo/mudboxtexturespaintingprob.jpg" border="0" alt="Photobucket"></a>
Message 11 of 18
Hi everyone
sorry for the bad english
WHY???
Message 12 of 18
Christoph_Schaedl
that looks like projection errors to me...
if you are projecting to a poly facing away from the cam you will get stretched textures...
may i see more screens..?
Message 13 of 18
Message 14 of 18
Message 15 of 18
Message 16 of 18
IMPORTANT
look this simple 'discover'
low poly mesh good spacing and no very thin rectangular UVS poly area work well almost perfect
<a href="http://s1080.photobucket.com/albums/j338/mastroprimo/?action=view&current=paintproblemsnew.jpg" target="_blank"><img src="http://i1080.photobucket.com/albums/j338/mastroprimo/paintproblemsnew.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1080.photobucket.com/albums/j338/mastroprimo/?action=view&current=paintproblemsnew2.jpg" target="_blank"><img src="http://i1080.photobucket.com/albums/j338/mastroprimo/paintproblemsnew2.jpg" border="0" alt="Photobucket"></a>
if i subdivide the model for sculpt , with subdivide UV first checked then unchecked the result is the same ,this
<a href="http://s1080.photobucket.com/albums/j338/mastroprimo/?action=view&current=paintproblemsnew3.jpg" target="_blank"><img src="http://i1080.photobucket.com/albums/j338/mastroprimo/paintproblemsnew3.jpg" border="0" alt="Photobucket"></a>
the texture is streched and if i paint the errors come out.
any ideas?
i fail some of simple because i do basic things wrongs?
Tank you.
Message 17 of 18
Christoph_Schaedl
if you like to use smooth uvs...
you have to do this on a clean unsubdivided mesh...
may i see the uvs and the mesh in this area on level0 with wireframe turned on..?
Message 18 of 18
Hi all,
i also have seams problems when painting on my model.
Here is the way i proceed to import my model in mudbox : i created the low poly model in 3ds max, i unwrapped the uv, and then added a turbosmooth modifier (2 iterations) in order to subdivide it. Then i exported the .obj file. (10 000 poly)
Should i instead export the lowpoly mesh and subdivide it in Mudbox for better results in term of seams ?
