Mudbox 2018 - Ptex export distorted on certain faces
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm currently painting a model in Mudbox 2018 using ptex. While painting everything seems fine. I can increase the subdivision level and paint without any distortions. But when I export the paintjob to a ptx file, mudbox for some reason distorts the texture on certain faces.
To be sure its not a vray bug (I first noticed the problem in my renders), I made a simple test inside Mudbox and re-imported the exported ptx file as a layer to the very model I exported it from. And well, I had the same distortions. That means for some weird reason Mudbox distorts the texture on some face's during the exporting process.
Btw I tried Mudbox 2019, same problem. It also doesn't matter whether I first subdivide and then setup ptex or the other way around. Same result all the time.
I hope anyone knows how to fix this very anoying problem.
The following images show the problem:
