MUDBOX 2018 DOES NOT IMPORT CREATED TARGA TEXTURES FROM PAINT - Solution!
iekomedia
iekomedia
I literally almost broke down until I figured I would give it a shot. I am using Mudbox 2018 planning to purchase sub after trial, I was painting for almost 6 hours and then crash. the whole computer, blue screen - DRIVER_OVERRAN_STACK_BUFFER
I restart reload mudbox, give I just saved about 5 min before the crashed loaded my scene and bam, no textures loaded.
I checked my files they were there, tried to do manual import and bam import error.
just as I started to break down because i'm on a time crunch and already 2 days behind trying to get the file into mudbox, I decided to open the targa files in photoshop on my second computer. The files opened with the details.
I went to the mudbox file and I loaded a tif file that was a solid color I was using for the base.
It loaded in just fine.
I converted the tga to tiff
pulled them over to the other computer and loaded them into mudbox and they loaded perfectly with alpha of painted areas.
I feel like this is a major issue because targa was what I selected from the file list so I would expect the program to support it. also
this is the major part, I saved as a revision that save as revision didn't save the details, the targa documents were the same size as the painted but when i opened them they were black. had I accidentally saved my main scene while troubleshooting I could have lost all the work I had done.
I hope this helps or saves someone.
jill.ramsay
I'm sorry you ran into this, and thank you for reporting it and posting your workaround. We will definitely look into it.
Jill
iekomedia
Thank you Jill,
I also went ahead and got the year sub, I also finished the paint, See the attached images, got it hooked up in Maya and have moved forward with the rest of the project.. Mudbox for the win!!
jill.ramsay
Looks great, James! Now that you have the subscription, be sure to download Mudbox 2018.1 - look for Updates & Add-ons in your Autodesk Account under Mudbox. We fixed a lot of things in that update!
Jill
