Hallo,
I´m Mudbox freshman. I have problem with grab tool. Generally I´m used to reset tool before use it from Maya. But when I reset grab tool this tool is unusable. After reseting grab tool it works like with very small amount of strength. Although there is for example strength 100.To make "factory reset" I have to delete Mudbox folder with settings. This is only way how to fix it.
Please can anybody giv me some advice what to do (except of advice "Don´t use reset" 🙂 )?
Thanks in advance. Peter.
Hi Pened,
If it is related to a Mudbox unexpected behaviour, we will be able to escalate this issue too our developers.
As for the Mudbox reset, you have this possibility:
Rename the prefs folder found in the following location to something like prefsOld:
Could you send us a print screen of the status do you get, or record a mini-video using Autodesk Screencast to help us to simulate your issue in our lab.
Best regards,
