Solved by absoluteKelvin. Go to Solution.
not sure why you would want to just stick to just mouse. but without tablet you won't get pressure sensitivity.
you get use to just using tablet once you use it more. I use mouse mostly in maya, but when it comes to sculpting and texture painting I use tablet. It flows a lot better. youll also find that it will put less strain on your wrist
you would need to customize the pen settings inside the Wacom preferences. set button one to be right click and the other to be middle click or vice versa. Left click isn't really need in case you're wondering. Just pressing the pen on the tablet is already left click, so its redundant
