Human mesh with 3 maps assign to 3 UVs issue bringing to MUDBOX
Hi
I just bought mudbox and I having a big issue....
I have a human biped mesh that contains 3 maps assigned 3 uvs for each (head, upper body, lower body)
I used to texture paint in 3d coat and when I import that mesh there it works great, 3d coat is able to identify all the different 3 uvs and let me paint just fine.
I am planning to switch from 3dcoat to mudbox, I imported the same mesh but I am having a hard time to separate those in different uvs...
am I missing anything obvious?
thanks
absoluteKelvin
 it sounds like you are using 3 set of uvs. What you need to do is combine the uvs in one set, then offset each set so they dont overlap each other.
kinda like the picture below.
ReadyToMariUvsSnapshot
here is a guide on UDIM/UVTILE uv layout
http://bneall.blogspot.ca/p/udim-guide.html
https://www.artstation.com/kelvintam
