The default Human Body mesh seems to be 8 heads tall, what should I do when I want to create a 7-heads-tall (or any other non-8-heads-tall) character? I'm trying to use Grab tool, and I just can't avoid distortions. Am I on the right track? Or is there any way to adjust proportion with other tools?
Solved by RobinBall6995. Go to Solution.
Just to add to RobinBall6995's answer, when you add a joint, you can middle mouse click to scale the affected verts. So you could add a joint for a body part then make sure only that body part's verts are green (affected), then middle mouse click to scale the body part.
