Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Export textures as atlas
1 REPLY 1
1043 Views, 1 Reply
Hi there!
I have 4 models created in Maya. I created a single UV map in Maya with these 4 models to behave like a texture Atlas.
I exported these 4 models to a Mudbox scene for high-poly and maps. I would like to keep the single file format - atlas UV map - I originally setup in Maya. However I could only see that Mudbox lets me export a single texture file for each channel (specular, opacity, etc) and for each model. It'd be quite painful masking each UV and texture of the 4 models in photoshop to keep the Atlas format.
Can Mudbox merge texture channels across different models in the same scene?
I also tried this in Maya but the UV Editor - Image - UV snapshot only shows information of one texture (as selected in UV Editor - Textures) if I take a UV snapshot. Is there a way to take a snapshot of the UVs with all textures as shown in the model in the maya scene?
Other suggestions to extract the textures much appreciated.
Thank you for your help,
Sergio
1 REPLY 1
Christoph_Schaedl
mudbox does not merge textures for different objects...
but they should have an alhpa... you could just stack them in photoshop...
use the export channelto PSD option...
https://linktr.ee/cg_oglu
