Hello all,
Im a beginner in mudbox and just testing the tools on the standard base mesh in mudbox.
It doesn't matter which tool I use, they are not smooth. I can't even make a line.
Saw option like deleting preferences etc. Doesn't work.
I don't know exactly how to explain it but in the image you can see a little bit.
When i try to sculpt it makes only pointy sculps. Like i'm making mountain on a persons head or something.....
And when i try to make a line in the mesh sometimes nothing happens on a part and on a other part it works but not smooth again.
Image 2 is supposed to be a line ... ?! (not at all)
Don't know what to do or how to fix this
Hope someone can help me.
Keep in mind i'm a beginner
Solved by imre.major. Go to Solution.
The resolution of your mesh is not adequate. You need to create additional subdivision levels (hit shift+D).
