Announcements
Why do my joints scale when I Plot to Control Rig?
When plotting motion capture data from an Actor to Control Rig the bones suddenly scale for no apparent reason.
Plot to the skeleton works; however also happens when plotting from the skeleton to Control Rig.
I have tried to put DOF limitations on Joint Scaling with no better results.
What am I missing?
brissef2
Hi @Anonymous,
It would probably help diagnostic yourissue if you would give us your fbx scene.
Best regards,
Francis
Here it is Francis.
Thanks, Jason
brissef2
Hi @Anonymous,
In your attached scene, I cannot see any actor, is this expected?
Could you please detail the exact repro steps leading to your issue?
Best regards,
Francis
Here's the full file with the Actor & all related models.
-Jason
I was having a similar issue.  I turned off Smart plot when going to the control rig and my problem is fixed.  Perhaps this will help you also!
