MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
my parent constraint tool
3 REPLIES 3
950 Views, 3 Replies
Hello everyone,
I started a blog where I hope to periodically post new tools, tips etc.
The 1st useful thing I've posted is a simple parent constraint tool:
http://www.sternativo.com/?p=146
any feedback, let me know 🙂
thanks!
3 REPLIES 3
hey I've updated the script.
Now is more efficient and it will change the name in the navigator based on the type of constraint (I've set it to work only on position, rotation and parent but it's easy to modify it) so it will look like this:
def constraint(CONSTRAINT_TYPE = 3, Weight = 100, SNAP = True, child = None , parent = None  ):
    #assign child and parents variables and check if the right amount of items are selected
    if child == None or parent == None:
        selectedModels = FBModelList()
        FBGetSelectedModels (selectedModels, None, True, True)
        if len(selectedModels) <= 1 or len(selectedModels)> 2 :
           FBMessageBox( "Error", "Please select two items", "OK" )
           return
    selected_objects = [FBFindObjectByFullName(model.FullName) for model in selectedModels]
    child = selected_objects[0]
    parent = selected_objects[1]
    CONSTRAINT_TYPE_AIM = 0
    CONSTRAINT_TYPE_EXPRESSION = 1
    CONSTRAINT_TYPE_MULTI_REFERENTIAL = 2
    CONSTRAINT_TYPE_PARENT_CHILD = 3
    CONSTRAINT_TYPE_PATH = 4
    CONSTRAINT_TYPE_POSITION = 5
    CONSTRAINT_TYPE_RANGE = 6
    CONSTRAINT_TYPE_RELATION = 7
    CONSTRAINT_TYPE_RIGID_BODY = 8
    CONSTRAINT_TYPE_3_POINTS = 9
    CONSTRAINT_TYPE_ROTATION = 10
    CONSTRAINT_TYPE_SCALE = 11
    CONSTRAINT_TYPE_MAPPING = 12
    CONSTRAINT_TYPE_CHAIN_IK = 13
    #setting te prefix for the name displayed on the constraint based on its type
    if CONSTRAINT_TYPE == 3 : constraint_name = "par_"
    elif CONSTRAINT_TYPE == 5 : constraint_name = "pnt_"
    elif CONSTRAINT_TYPE == 10 : constraint_name = "rot_"
    else: constraint_name = ""
    #constraint creation with type and name
    myManager = FBConstraintManager()
    myCons = myManager.TypeCreateConstraint(CONSTRAINT_TYPE)
    myCons.Name = constraint_name + child.Name + "_to_" + parent.Name
    #adding elements to the constraint slots
    #for index, element in enumerate(selected_objects):
    myCons.ReferenceAdd (0, child) #if I add an index > 1, it wont be added to the slot(dont know why)
    myCons.ReferenceAdd (1, parent) #if I add an index > 1, it wont be added to the slot(dont know why)
    #setting up the snap option, so the elements will keep their position
    if SNAP == True:
      myCons.Snap()
    #weight of the constraint
    myCons.Weight = 100
    myCons.Active = True
hope it helps 🙂
Hi xatmo, well written!
Instead of putting number as argument to specify type of constraint, i would use the name of the constraint instead. Because you would forget which number is for generating which constraint very soon and you wouldn't want to read your script everytime you use the function.
i.e constraint(CONSTRAINT_TYPE = 'Point', Weight = 100, SNAP = True, child = None , parent = None )
my 2 cent.
yes good point. Somebody else addressed this feedback and I've fixed it already but I didn't update it online 😛
thanks!
