How to use python to realize the function in the picture
410299258
410299258
Mocappy
It's hard to know what you are doing from the picture...
If you want to select all mesh/geometry objects, this should work...
Find all FBModel objects
Check component is not a camera
Check component has geometry (FBMesh, FBSurface, FBNurbs, FBPatch)
Check geometry isn't system geometry (Motion Blend Result)
Select
for component in FBSystem().Scene.Components:
    if component.Is(FBModel.TypeInfo)\
    and not component.Is(FBCamera.TypeInfo)\
    and component.Geometry\
    and not component.Geometry.HasObjectFlags(FBObjectFlag.kFBFlagSystem):
        component.Selected = True
If you wanted to select all geo in a character hierachy, you could switch the search from all components in the scene, to all coponenets in a hierachy.
Hope this helps,
Sorry i didn't make it clear
Actually what I want is the function of the picture below
vdebaie
Here is something I quickly created based on a previous post we had in this forum:
from pyfbsdk import *
from pyfbsdk_additions import *
def bSelOtherObjWithSameNameSpaceCallBack(control, event):
    selModels = FBModelList()
    FBGetSelectedModels (selModels, None, True)
    if len(selModels)>0:
        objNameSpaces = []
        for model in selModel:
            nameSpace = str(model.LongName.rsplit(':', 1)[0])
            objNameSpaces.append( nameSpace )
        for namespace in objNameSpaces:
            FBSystem().Scene.NamespaceSelectContent(namespace, True)
def PopulateTool(t):
    bSelOtherObjWithSameNameSpace = FBButton()
    x = FBAddRegionParam(5,FBAttachType.kFBAttachTop,"")
    y = FBAddRegionParam(5,FBAttachType.kFBAttachLeft,"")
    w = FBAddRegionParam(-5,FBAttachType.kFBAttachRight,"")
    h = FBAddRegionParam(-5,FBAttachType.kFBAttachBottom,"")
    t.AddRegion("bSelOtherObjWithSameNameSpace","bSelOtherObjWithSameNameSpace", x, y, w, h)
    t.SetControl("bSelOtherObjWithSameNameSpace", bSelOtherObjWithSameNameSpace)
    bSelOtherObjWithSameNameSpace.Caption = "Select Obj With Same Name Space"
    bSelOtherObjWithSameNameSpace.Style = FBButtonStyle.kFBPushButton
    bSelOtherObjWithSameNameSpace.Justify = FBTextJustify.kFBTextJustifyCenter
    bSelOtherObjWithSameNameSpace.Look = FBButtonLook.kFBLookNormal
    bSelOtherObjWithSameNameSpace.OnClick.Add(bSelOtherObjWithSameNameSpaceCallBack)
def CreateTool():
    t = FBCreateUniqueTool("Select Objects With Same NameSpace")
    t.StartSizeX = 250
    t.StartSizeY = 65
    PopulateTool(t)
    ShowTool(t)
CreateTool()
Mocappy
A lot depends on how your character and scene is setup...
Like Vic said, you can use namespace (usually best/safest option). But as Aragon is in a single hierarchy, you can also select everything in the hierarchy with something like this:
def select_entire_hierarchy(rootObject):
    Select all objects in Hierarchy
    def _select_all_children(model):
        model.Selected = True
        for childModel in model.Children:
            _select_all_children(childModel)
    _select_all_children(rootObject)
def get_selected_root_obj():
    Get root object in selected hierarchy
    def _get_root_obj(model):
        if not model.Parent:
            rootObj = model
        else:
            rootObj = _get_root_obj(model.Parent)
        return rootObj
    selectedModelList = FBModelList()
    FBGetSelectedModels(selectedModelList)
    if selectedModelList:
        selectedObj = selectedModelList[0]
        selectedRootObj = _get_root_obj(selectedObj)
    else:
        print "ERROR:Nothing Selected"
        selectedRootObj = None
    return selectedRootObj
rootObj = get_selected_root_obj()
if rootObj:
    select_entire_hierarchy(rootObj)
Then you can filter the "select_entire_hierarchy" for whatever you want, e.g. mesh, skeleton, etc.
Good luck,
