Announcements
How do you render without the grid in MotionBuilder 2017?
Message 1 of 9
Just learning MotionBuilder and wanting to render without the grid showing up in my .jpg and/or my .avi, but I can't find the control that will allow me to hide the grid.
Thought it might be like 3ds Max and just toggle the grid on/off with 'G' but not so for MotionBuilder.
Is there a render setting that would allow me to produce a model only, no grid .jpg or .avi?  Do I need to add 3D assets such as a plane for the model to stand on / move across to hide the grid or?
**Also...why do the Autodesk Character Generator characters eyes turn black when I import them into MotionBuilder?  The current character that I've named Bette D. was selected to have bright blue eyes but when I imported her they turned completely black and we're talking pupils, coloration and where the whites should be, ends up looking like a demon?! Weird!
I've attached the picture so you can see her with the grid I wish to eradicate and the demon black eyes I'd like to change to the selected blue eyes.
Thank you for all the help you've all given me over this past year while I'm in school.  I hope someday to repay the kindness to others once I learn enough to help too.  Hopefully one of you will be able to help me this time too.
Sincerely,
Crystal
Accepted solutions (3)
Replies (8)
Message 2 of 9
On the grid situation, the options are under the camera. Select your camera on the navigator and you should find it quite easily.
I don't think there is a keyboard shortcut to it, although you could set one via scripts (let me know if you'd like to learn about that, to achieve something just like Ctrl-A lets you hide the skeleton/rig)
About the demonic eyes, I honestly can't tell. I only used the Character Generator once in my life and this issue didn't happen.
Until someone here has a more accurate answer, I'd try:
-Double checking it the eyes are single meshes or if there is a cornea model on top of it. Some models come with a transparent cornea and MoBu might just display an opaque material. If so, you can hide such extra models (shift-H);
-Going to the eye mesh on the navigator and checking its material (it appears as children of the node). If something got lost in the way, you could even drag your texture file (probably generated inside a "<filename>.fbm" folder if you downloaded an .fbx file) directly over the mesh in the viewport and attach the new (hopefully correct) texture to the material.
These suggestions might not help in your case, but one can try 🙂
Message 3 of 9
Thank you so much, phscatena,
Can you also take a look at my class project?  I did all the steps to make my character speak the movie audio clip for the assignment, but her mouth doesn't move?  I've probably done some newbie / rookie mistake.  I've attached it in a zip file
Sincerely,
Crystal
Message 4 of 9
Hey, glad to know it helped!
I opened the scene (the black eyes were indeed caused by extra models, huh..). I have no familiarity whatsoever with using the voice device.
However, when I first opened your scene, it played (blendshapes were moving). After the audio reached its end, it didn't anymore. This seemed odd, so after testing some properties, I selected the audio file (under Devices > Voice), and going to its properties (Properties tab) I changed "AccessMode" from Disk to Memory. Then it seemed to work.
Was that your problem? Or was if about the teeth not moving? Because for that you'd have to figure a way for the device to control the shapes of the "m_TeethDown" geometry.
Good luck on this assignment of yours 🙂
Message 5 of 9
Thank you!! This is invaluable for my assignments due for final this weekend!! I'll come back next week to post here so you're able to see how you helped! 🙂
Sincerely,
Crystal
Message 6 of 9
carola.blochA8WTM
Hi Crystal and phscatena,
I came across your discussion because I have the same problem with black eyes after importing my character from Character Generator to Motionbuilder. @Anonymous was it the extra cornea model on top of the eyes as @Anonymous suggested? Or did you find another solution? I thought it might be a false lighting in the scene but even a bright frontal spotlight did not help, so I would be happy to hear about your solution.
Thanks a lot and best regards,
Carola
Message 7 of 9
Good morning, Carola,
     Yes, it was the suggestion that @phscatena provided
     But tbh I'm really into Blender these days. Currently poised to graduate with an AAS in 2D/3D for Film, Television & New Media. We primarily use Blender (it's a free 3D modeling & more software engine) along with Adobe CC, Z-Brush and Substance Painter. It's good to know as much as possible though, so you're ready for all kinds of projects (Blender, 3ds Max, Maya, Cinema 4D, etc.).
    You're doing the right thing though, going to the forums, it's the best place to find nice people with the knowledge, skills and abilities to help you find the answers you need.
   Hope that helps, and I hope you have a terrific day! 🙂
Best Wishes,
Crystal
Message 8 of 9
carola.blochA8WTM
Thanks so much for your reply and thank you both @Anonymous and @Anonymous for your comments - it worked out for ma as well, I removed the cornea models in the model hierarchy and now my character has eyes! 🙂
And thanks for the hint to Blender, maybe I'll try this if Motionbuilder will not work our for my project.
Have a very great day as well!
Best regards,
Carola
Message 9 of 9
Yay!!  I'm so glad everything worked out for you, @carola.blochA8WTM
Happy modeling!! 😄
