Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Why shrinkage percent of injected model is greater than material shrinkage ?
3 REPLIES 3
nguyenbuulam
246 Views, 3 Replies
Dear Moldflow Support/ Moldflow user
I would like to inquire your issues:
I run a procedure Fill+Pack+Warp of uniform and simple shape with material Xyron DG040.
Material shrinkage value is as below
I checked shrinkage percent of injected model is greater than material shrinkage.
How can this issue occur ? Why shrinkage percent of injected model is greater than material shrinkage ?
Thank you in advance for your support.
3 REPLIES 3
mason.myers
in reply to: nguyenbuulam
Hello @nguyenbuulam ,
What is the thickness of your part?  The tested shrinkage values we show are an average from our CRIMS test plaque.  This plaque can vary in thickness but the data is usually taken from 1-5 mm thick samples.  If the thickness of your part is greater than our test plaque, you will see higher amount of shrinkage.  If the part is not packed our sufficiently, you can also see high shrinkages.
Mason
nguyenbuulam
in reply to: mason.myers
Thanks to Mr Mason for your prompt support
Hi.
Generally, thicker part, lower holding pressure(process setting or far from the gate), hotter temperature(melt and mold) and shorter holding time makes greater volumetric shrinkage.  Flow direction shrinkage is smaller than perpendicular shrinkage value particularly on filled material such you used.(This is already written in "observed shrinkage" table.)
Regards.
