Hello, I can not find information how to set 2K injection "wet in wet"? (MP/DD/3D?)
The task is to have border between two materials (different MVR) on specific place of the part.
I am not able to set 'Overmolding Injection locations' of (second) material ... maybe because I have not fixed wall between these two materials.
Please, can you help me how to set the task properly?
Solved by Halasur. Go to Solution.
Other name for "wet in wet" is probably "bi-injection molding" ...
... and seems available only in Ultimate version of Moldflow 😞
http://www.autodesk.com/products/simulation-moldflow/compare
For Bi-injection molding you should have ultimate license, the component should be in mid plane then only this Bi-Injection molding option will high light.
Regards
Aravind Halasur
