Wall slip in fill analysis
tzvikad
tzvikad
What is the equation (Mold flow is solving) when including wall slip analysis?
Is there a specific equation for the wall slip velocity ?
I'm using the Insight Ultimate 2018 version
mppkumar
Hi @tzvikad
refer this link: https://knowledge.autodesk.com/support/moldflow-insight/learn-explore/caas/CloudHelp/cloudhelp/2018/...
Hope this link clarifies your doubts
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
I was allready doing some analysis including wall slip. Refer to the link mppkumar provided.
The main Problem ist that in the there is almost no Materialdata regarding the slip coefficient and the slip exponent, and these vary greatly in Order.
I also think that the critical shear stress is not as universal as proposed in most papers (0.1MPa) since I allready had parts with severe slip where the shear stress in the simulations was much lower.
I found some references in the book Flow analysis of injection molds from Kennedy and Zheng. But nothing regarding the material I was interested in.
You will also find many papers regarding wall slip if you do a search on google scholar (keywords: extrusion instabilities, wall slip,  Hatzikiriakos, Rosenbaum)
If you get some data for PA66 please let me know.
Thanks and good luck
Regards
Axel
tzvikad
Thanks a lot, it's perfect
Zvika
