Volumetric shrinkage result has negative value
Sanjay_paul
Message 1 of 10
Sanjay_paul
Hello everyone,
In the below picture there showing negative volumetric shrinkage on some areas. What does this mean?
Regards
Sanjay Paul
Replies (9)
Message 2 of 10
bernor_mf
Hi Sanjay,
Negative volumetric values indicate expansion rather than shrinkage.
Negative volumetric shrinkage means expansion : the material does not shrink, rather expand.
If you see this,area of the part is overpacked - in filling phase and/or in packing phase.
Negative volumetric shrinkage in features like ribs, bosses etc means higher risk of getting stuck in mold, and cause ejection problems.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Message 3 of 10
Sanjay_paul
That means the packing pressure is greater than required. I have set 60% of fill pressure as packing pressure. How much packing pressure do you recommend for running an analysis? How much should I reduce?
Regards
Sanjay Paul
Message 4 of 10
mppkumar
Hi @Sanjay_paul
It's not only packing pressure ... packing time also matters
generally on the thinner regions like ribs it may be there (it's best practice to avoid it)
in your case, the negative volumetric shrinkage values is very close to zero, this can be neglected
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
Message 5 of 10
madhukeshwart
@Sanjay_paul
Negative volumetric shrinkages means the part will actually expand on removal from the mold.
This effect occurs if there is residual pressure inside the part at the end of the molding cycle.
Typically negative volumetric shrinkages are associated with excessive packing pressure.
Refer
1. http://forums.autodesk.com/t5/moldflow-insight-forum/negative-volumetric-shrinkage/td-p/4754459
2. http://forums.autodesk.com/t5/moldflow-insight-forum/negative-value-for-volumetric-shrinkage/td-p/34...
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: [email protected]
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Message 6 of 10
@Sanjay_paul normally negative volumetric shrinkage indicates that you are over packing the part. this negative Volumetric will help you understand that you are giving excessive packing pressure or over packing the part. with that you can easily optimize the required packing pressure which this part actually needs.
Message 7 of 10
Sanjay_paul
Thanks everyone for your comments. It was really helpful.
Regards
Paul
Message 8 of 10
ktr.mech
Could you please tell me the solution of negative volumetric shrinkage ,
what we are going to do ?
Message 9 of 10
bernor_mf
negative volumetric shrinkage means significant over packing.
Review your packing pressure level and time.
Adjust and profile the packing in time and pressure level for a more uniform volumetric shrinkage.
Hope this helps.
Berndt
Message 10 of 10
Good Morning, I am currently having an issue with 3mm of Negative Volumetric Shrinkage in the X direction and 1.8mm of Positive Volumetric Shrinkage in the Y direction on the actual parts.  Mold flow indicates the Negative shrinkage almost spot on and indicates only .5mm of Positive shrinkage. Any help or advice with correcting this would be greatly appreciated.
