use a script to extract the cavity weight results and deflection,all effects:Deflection results
1292909313
1292909313
I want to use a script to extract the cavity weight results and deflection,all effects:Deflection results of 100 items into a csv file, what should I do?
bernor_mf
@1292909313
a way of doing this is to loop through all studies in the project.
Basically a script that opens each study with results and read the label info.
Open the study.
Get the max and/or min value from result label.
Write info to a file.
Close the study.
Attach a piece of code that shows max value from result plot "Cavity weight" and
for "Deflection, all effects:Deflection".
SetLocale("en-us")
Dim SynergyGetter, Synergy
On Error Resume Next
Set SynergyGetter = GetObject(CreateObject("WScript.Shell").ExpandEnvironmentStrings("%SAInstance%"))
On Error GoTo 0
If (Not IsEmpty(SynergyGetter)) Then
	Set Synergy = SynergyGetter.GetSASynergy
Else
	Set Synergy = CreateObject("synergy.Synergy")
End If
Synergy.SetUnits "Metric"
Set PlotManager = Synergy.PlotManager()
ResultName = "Cavity weight"
Set Plot = PlotManager.FindPlotByName(ResultName)
Set Viewer = Synergy.Viewer()
Plot.SetScaleOption 0
Viewer.HidePlot Plot
Viewer.ShowPlot Plot
maxV = Plot.GetMaxValue
minV = Plot.GetMinValue
MsgBox ResultName & " = " & FormatNumber(maxV,2,,,0),,"Information"
ResultName = "Deflection, all effects:Deflection"
MsgBox ResultName & " Max= " & FormatNumber(maxV,2,,,0) & " Min= " & FormatNumber(minV,2,,,0),,"Information"
Hope this helps as a starting point to move forward.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
