Underfill and wafer molding
Hi all
Is there any body can help me how to get a sample demo study file for (a) underfill encapsulation molding (b)wafer compression molding (keep the charge and compress from top into the IC package)
Seems that no such models available across internet.
with thanks and regards
Singaram Ravi
madhukeshwart
Ravi,
  • Be in touch with Your Local reseller and Autodesk tech support team. They may help you to get the studies if they have.
  • Or else If they understand your process & If moldflow is capable to to simulate the same process and they may create the same for you
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: [email protected]
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
