Time to reach ejection temperature
madhan_rm
madhan_rm
When i check time to reach ejection temperature result, say for a component it shows 130sec to cool down completely but when time scaling adjusted b/w 40 to 50sec, 95% of part is cooled down and only the 5% of the remaining part takes more time to cool down. Now can i eject the component around 50sec in practical condition that is at 95% frozen
though 5% remaining is functionally important..?
Madhan.
MayumiO
Autodesk Support
Autodesk Support
Hi @madhan_rm,
Thank you for posting the forum!
Your view is correct.
In actual molding, there is the tendency that the part is ejected earlier than "time to reach ejection temperature" result in Moldflow if the stiffness is enough to eject it and the center of the part has not frozen yet.
At first, it is recommended to compare the part between real molding and the analysis result to judge which % of freeze is needed to eject it. (e.g. Check the part temperature result on the ejection timing in the real.)
I hope this will help you.
Please let me know if you have any questions or concerns about the above.
Mayumi
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Mayumi Oshita
Techinical Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
