Temperature for amorphous and semi-crystalline materials
praphotSYZN3
praphotSYZN3
Dear all
Have questions about the message as below? , What does this mean?
What is the target temperature for amorphous and semi-crystalline materials.?
and where can I find the these.?
"The minimum and maximum mold temperature should be within 10°C of the target temperature for amorphous materials." and within 5ºC for semi-crystalline materials.
Please suggest for me.
mason.myers
Hello @praphotSYZN3 ,
If you select the material that you want to use in your simulation, you can then go to the material details page by right-clicking on the material from the Study Tasks pane.  Each material will have a recommended mold temperature value.  You can use this value as a starting point or a suggested mold temperature value from the material TDS or SDS.
Mason
praphotSYZN3
Dear Mr.Mason
Thank you for your support,  I have some doubt.
please see the picture as below.
1.Mold surface temperature, Should I use it with Temperature, part or Temperature, mold.?
I have a little doubt about TDS or SDS
2. Material TDS or SDS , Can I search from the Google web right.?
or if can you share the link to me, I am thank you.
mason.myers
Yes, you would compare to the Temperature Mold plot.
You should be able to find the materials TDS or SDS online.
I do not know the material you are using so I am unable to send you the TDS/SDS.
Mason
praphotSYZN3
Thank you for your support.
