temperature export AMI 2015
i had a questition.
Is it possible with AMI 2015 to export the pemerature of the part at the ejection time?
I need this temperature distribution for a following FEA (Abaqus) simulation.
Best regards
Günter
inba_oneway777
You can export as a .XML file.
1. Open the " time to reach ejection temperature plot'
2. Result-> Export and publish -> XML
It will help you to extract the results from moldflow.
Inba Sudhahar D
Mail: [email protected]
Phone: +91-9884929216
if the answer is accepted as a solution. Give Kudos as appropriate to further enhance these forums. Thank you! .....
Hi!
Thx!
I´ll test it.
Best regards
Günter
