Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Speaker Grill Structure Modelling
4 REPLIES 4
umut.yerlesen
843 Views, 4 Replies
Hello everyone,
I need advice about preparing mesh model of the small blind and open holes contained on the some speaker cover parts. I inspected shape factor and equivalent thickness using is useful way for modelling but i'm not sure is that best way for modelling with DD or 3D meshing. I tried standart meshing procedures (for DD and 3D mesh) mesh element amounts achive 4.5-5M. Solver and my pc capacity not run analysis due to too much elements amount.
Could you share your experiences with me about meshing strategy for like this parts?
4 REPLIES 4
Good explanation from Sachin here about shape factor comparison between DD, Midplane, 3D and Shape Factor method.
Autodesk Moldflow Shape Factor - YouTube
Of course 3D is the most suitable mesh type for these features. But Midplane is more practical considering the long calculation time of 3D. And for big, shell-like parts, we nuormally use Midplane. If you want, we can introduce a China mesh vendor to you.
Hi simulators,
Personally, when it is possible, I use Midplane models.
It’s faster and quite reliable versus the reality.
In the areas with opened holes, I set the thickness of the material separating the holes.
In the areas with blind holes, I set the thickness of the material in the bottom of the holes.
Except if it is thinner than the one separating the holes.
Good luck.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
thank you for your helpful comments.
