Hi @sea512 ,
you are welcome.
Thank you for providing the details,
I better understand your issue.
Yes, you got it right:
Cool assumption : starting point for iterations is melt temperature as keyed-in in process settings.
This temperature will not change during simulation.
Flow: melt temperature a starting point, but could get shear heated during filling, increasing melt temperature.
Yes, I agree that the temperature from fill results should be used.
Some comments:
Be careful of used node to trace temperature.
So not in shear region, as this might show higher shear heating that thermocouple actually measures.
You could to an Temperature: Probe XY plot at same position as node, to understand what happens
with temperature through thickness over time.
The starting melt temperature in your case: 210C
The real value from thermocouple shows starting around 210-212C : a little shear heating
Moldflow: shows more shear heating at point/node at distance from thermocouple 225 - 239C : so quite a difference.
So the shear heating in Moldflow is higher than expected.
Could depend also depend on trace node position used.
Now, the shear heating of melt seems to happen upstream from node in plot.
Try to follow it back stream to understand where and why it starts.
Is it in sprue, runner, gate, and adding up?
Check temperature at sprue start, and then at gate: has temperature already increased 10-15C?
Then the runner system shear heating is increasing the melt temperature.
The mesh: how many tetra layers?
How thick is the part?
You might need more than default 10 tetra layers through thickness to capture what is going on.
Further, I noticed that the temperature slope from thermocouple trace is slightly steeper than Moldflow.
This could be due to Mold-melt Heat Transfer Coefficient (HTC) should be different for thick wall.
You can change this to investigate, if needed.
In Process settings > Advanced options.. Solver parameters > Edit...
tab Mesh ; default:
Filling HTC 5000 W/m^2
Packing HTC 2500 W/m^2
Detached HTC 1250 W/m^2 (part is detached: i.e., pressure is zero)
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
