Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Problem while using studymod for changing material properties
0 REPLIES 0
Message 1 of 1
akhileshchandgude
133 Views, 0 Replies
When using the studymod utility to alter a standard material's (e.g. Dupont material )material parameters (e.g viscosity parameter) in a study file by modifying the parameters through an xml file. The standard material gets transformed or changed into Generic PP (Polypropylene):Generic default material in the modified study file. How to solve this issue where I want to keep the same standard material in modified study as available in the original file?
 Has someone used studymod to change the material properties or how to change the material properties of the material without using the GUI?
Thank you for the answers in advance
Labels (3)
0 REPLIES 0
Technology Administrators
