Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Pressure plot
2 REPLIES 2
klp2kor
444 Views, 2 Replies
Pressure plot
I am working on a Fill+Pack analysis of an Insert molding. Few electrical pins (metal) are insert molded during molding. I want to measure the pressure exerting on the metal pins during molding. I need this value for further structural simulation.
So, from "Pressure XY" plot I plotted a graph for few nodes on the insert surface. Is it the right value of pressure exerting on the metal insert ?
I am asking this because the explanation of "Pressure" and "Pressure gradient" in AMI help confused me.
regards,
KL
2 REPLIES 2
cookp
in reply to: klp2kor
Yes, you can use the XY pressure plot to find pressure on inserts.
To improve our Help, can you tell us more about what help page you looked at, and what was confusing.
madhukeshwart
In AMPI, you need map pressure or temperature results to a mold mesh surface for export to ANSYS for core deflection analysis.
Call your local autodesk tech support. They will help you
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
