Moldflow don't result of Deflection, all effects: Deflection
nguyenbuulam
nguyenbuulam
Dear Moldflow support
Could you help me below issue.
I run procedure Fill+Pack+Warp, then there is no result of "Deflection, all effects: Deflection"
it result Deflection: Path Plot. I try to creat new .mpi, there is same issue.
In the previous project, I use Deflection: Path Plot to process the result. Does it seem to be the root cause?
May you help me how to solve this issue ?
Thank you in advance for your support.
bernor_mf
@nguyenbuulam
Pretty strange what happens.
I do not think it should be inherited as you describe.
First, hover over Results in task pane, right-click and select : "Add Default Plots".
To see if that would resolve the issue, and adding Deflection, all effects:Deflection.
Further:
If something happens with UI, lost dialogs and other strange things, a cleanreg could help.
Sometimes a cleanreg could solve odd behaviours.
Running a Clean Registry in Simulation Moldflow Products
You are having odd issues with directory access, results access, as well as general usability concerns and need a quick fix without having to go through the entire reinstallation process. A clean registry does just this, by cleaning out the registry and reconfiguring the installation to default settings and removing any configurations that may be causing those issues.
After a cleanreg, you might need to rerun the simulation.
But first have a look on results, and repeat : hover over Results in task pane, right-click and select : "Add Default Plots".
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
nguyenbuulam
Thank you Mr Bernor for your solution.
"Running a Clean Registry in Simulation Moldflow Products" is the useful and effective solution.
bernor_mf
@nguyenbuulam
Happy to hear it resolved your issue. 🙂
Thank you for sharing this with the community.
Berndt
