Dear Moldflow User community.
First of all, on behalf of the Moldflow team I want to wish everyone a great 2017! Last year was certainly an exciting and successful year for the Moldflow products, and we start the New Year with the release of Moldflow 2017.3! This is now available from the Product Enhancement section on Autodesk Accounts (link) for customers on active maintenance or subscription contracts.
Some of the main highlights:
The Moldflow 2017.3 can be installed next to your previous Moldflow releases, installs using your 2017 Product Key and Serial numbers, and uses the normal Moldflow 2017 licenses.
The team is already working hard on the next releases!
Again, all the best for 2017, and I hope to see you somewhere at a Moldflow event this year.
The Moldflow development team.
Hello Hanno,
when I try download Moldflow, I can't be sure which release it is.
It says MFIA 2017 R1?
R1? Shouldn't it be R3?
Could the server manage it in a way that I can see the major releases and the quarterly releases and choose precisely?
Thanks in advance
Harald
Hi Harald,
Firstly; it is really 2017.3 :-), but I think you are looking at the wrong place. I recorded a short video here. that should show how to get to the right spot.
If you do NOT see this, try to change your language preferences and set it to English. We had some problems displaying the entitlement for non-english language preferences (back to the 'Profile tab' > 'Preferences' > 'Language' --> English, then try again). I thought we had gotten this resolved, but if not, than I would really like to know that as soon as possible.
Going forward in 2018.0, we intend to be able to use the Autoesk Desktop App to provide new installers for your product. For a technical reason, we are currently not able to use this but my understanding this will be resovled. This will provide a much cleaner experience for you as a user.
Hanno
Hello @harald_goetz,
the names of the files should be (I added the link where my browser downloaded it from):
The Linux versions are:
I hope this helps.
Thanks a bunch M. Brassel!
I have to figure out why I can't see these files.
But at least I could download them from your links.
This is the 2nd time I can't see files of the quarterly releases immidiatley.
I'm curious now for April/ May 2017...
Best regards
Harald
Hi Harald,
I will try to get someone in support to connect with you, as we will need to know for sure if this is related to a specific setting for you or a much broader problem.
I'm truely sorry for the trouble you are having.
Hanno
Just for the record:
Recently I couldn't access the product enhancements page with Firefox, I am always landing at the page https://accounts-subs.autodesk.com/sc/error_login.jsp
With Internet Explorer I am able to open the page and it looks like the following in English:
and in German:
So the problem with the language has been solved.
@raalteh wrote:
- Improvements in Mesh preparation (Automatic mesh sizing, Create CAD body in Mold block wizard)
Nice work with this - I'm impressed with the Automatic mesh sizing and CAD body creation. It took a few goes to get my head around ignoring the Global Edge Length setting.
Hello everyone.
I have some problems after update with "file transfers from server". I have server on the same PC where I`m preparing analysis. I don't know how it works but server it's mean SOLVER at this situation?
For e.g. I have problems with 3D meshing. Logs shows "Percent 100 done", in Simulation Job Menager is also 100%.
Thanks in advance for every suggestions.
Dear Chanchai,
I would suggest you contact support for this, either through your reseller or direct.
Hanno
