Hi All,
I'm new to Moldflow and just finding my feet. Whilst trying to carry out some of the tutorials, i've noticed i have some icons missing such as mesh, dual domain, optimization etc. i can't seem to find these icons anywhere or add them to the toolbar. Can anybody help me out with this? Thanks in advance
Solved by nordhb. Go to Solution.
the picture you provided shows your are using Autodesk Simulation Moldflow Adviser.
To work with mesh you need Autodesk Simulation Moldflow Insight.
See:
Moldflow Insight vs. Moldflow Adviser
http://www.autodesk.com/products/simulation-moldflow/compare
Hope this clarifies.
Berndt
Thanks Berndt, i kind of understand now. Shouldn't I at least have dual domain & possibly 3D meshing though?
Regards
Jordan
Hello Jordan,
yes, you can set mesh type:
In Moldflow Adviser, after import, right-click on analysis sequence (where it says Fill or so).
There you can switch: Change To True 3D or vice versa Change To Dual-Domain.
Berndt
