Meshing issue in insight 2024
veeramunishwaran.veeraselvam
In insight 2023 and older version, while meshing if meshing is not possible it will show us the error face which will help us to solve and re mesh that part, why that function is not available in 2024?
is it possible to add it again?
bernor_mf
HI @veeramunishwaran.veeraselvam
this is also discussed in following thread:
AMI-2024 / Mesh log information when meshing process failed
Autodesk asks for the model to be able to troubleshoot.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
yes, In that post they have talked about the same issue,, but without a solution, if we got some solution to it, it would be fine, because not only this issue, some models which we are able to mesh in 2023 version doesn't work on 2024.
bernor_mf
Hi @veeramunishwaran.veeraselvam ,
right, no solution provided.
Would be good to get the information in mesh log back.
Sometimes I have got this issue when using native CAD format.
A workaround that sometimes has resolved this issue is using STEP-format.
Seems as this sometimes can "heal" bad faces.
Worth a try, I think.
Berndt
