[MACRO] Refresh of the View
Message 1 of 11
Hi everyone,
I'm encountering a problem with my developments ... In my macro, I hide and show some layers but somehow, the layers are "untick" but stay in the View ... somehow, the view does not refresh ... Do you have any idea on how to prevent this comportement ?
However, when I force the refreshing by showing a node layer manually, the view is refreshed ... But how to force the refreshing in my macro ?
Thank you for your help
Enjoy your day !
Replies (10)
Message 2 of 11
bernor_mf
strange behaviour you see.
Do you see the same in Synergy 2016 and Synergy 2015?
As there were a change of layer layout in 2016. Not sure if this really affects the view update...
There is unfortunatley no object as Viewer.Refresh
Maybe you could try Viewer.Reset ?
Set Viewer = Synergy.Viewer()
Viewer.Reset
It will rotate to default position, hence update the view.
Or maybe trick the viewer to update in another way, with a small rotate or something like that?
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Message 3 of 11
Hi bernor_mf !
Thank you for your answer however, I cannot try if my macro works on MoldFlow 2015 ...
However, I tried with the Viewer.Reset command but my layers still work wrongly  😞
Do you have any other idea ?
Thank you so much for your help
Message 4 of 11
bernor_mf
Hi nkelle,
are you using this kind of code:
Set LayerManager = Synergy.LayerManager()
Set EntList = LayerManager.CreateEntityList()
EntList.SelectFromString "L4 "
LayerManager.ShowLayers EntList, False
where False turns layer off and True turns it on.
Did a quick test, and it looks ok in graphics to use this code. It showas and hides as expected.
Berndt
Message 5 of 11
Yes, I use this kind of code :
sub HideLayers(startString)
	Set LayerManager = Syn.LayerManager()
	Set L1 = LayerManager.GetFirst()
	LName = LayerManager.GetName( L1 )
	Do While LName <> ""
		LName = trim(LayerManager.GetName( L1 ))
		if Left(LName,Len(startString)) = startString then
			LayerManager.ShowLayers L1, True
			LayerManager.ShowLayers L1, False
		end if
		Set L1 = LayerManager.GetNext(L1)
	Loop
end sub
But somehow, sometimes it doesn't work ...
Message 6 of 11
bernor_mf
Strange it doesn't work.
Maybe the system cannot react so fast?
I would try to add a waiting time to see if it helps, like a few seconds:
WScript.Sleep 2000 '** the time in ms, milliseconds : this will wait for 2 seconds LayerManager.ShowLayers L1, False
Berndt
Message 7 of 11
Well, it seems to be OK ... I don't know why but thank you for your solution !
Message 8 of 11
bernor_mf
So adding a waiting time resolved the refresh issue?
Did you use 2000 ms or trimmed it to shorter waiting time?
Just curious of the outcome.
Thanks.
Berndt
Message 9 of 11
I used your preconisations :
Message 10 of 11
bernor_mf
Thanks!
Good to know.
Right, seems as system needs a waiting time to be able to execute as wished.
I have seen this occasionally in other situatuions, and adding a short waiting time resolved issue.
(Another example when saving a study, a wating time could be needed before next step.)
As using 2 sec in loop, it might slow down execution if many layers.
I would recommend to trim the time, by testing 0.5s (500 ms) if not ok, then 1s (1000ms) and so on.
Berndt
Message 11 of 11
I just tried 500ms, 1000ms and 1500ms and it does not work so I'll keep the 2000ms of delay 🙂
