Macro editing/ Script documentation help
lumineyn
lumineyn
Hi!
I got placed in a project where i have to modify process parameters in Moldflow (mold temperature, cooling time, pressure and so) and would also need to tamper with the position of the charge if possible. The license i got only has the record macro option (no built in VB editor). I looked through the tutorials and the provided examples here, but I'm at loss where to look for the correct functions, structures or generally documentation for this. I have looked for general examples, but keep getting error messages that the following methode "StudyDoc.Open" is not known (example of something i found but did not work).
I'm very much at loss and don't know where to look for references and help. I have Moldflow Insight 2023 with a university license.
Thank you very much in advance if you could help me out 😞
fqlb
You can search for a file named solverapi.chm in the Moldflow installation directory , You can also search for relevant example code in the installation directory under data/commands/
bernor_mf
@lumineyn
Even if you looked through a lot of documentation, I think this is a good starting point:
How to find the Application Programming Interface (API) documentation and reference in Moldflow
It has some links to Autodesk University presentation about the basics.
I think you could also search this community for API for discussions and solutions.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
adevadkar
HI@lumineyn
you can get help from .
Here you can find the synergy related classes and some examples.
Also in solver API you will get information related to solver classes.
Thanks & Regards
Anirudha D.
