Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Is it possible to import mfr?
5 REPLIES 5
aonotaka96
258 Views, 5 Replies
  • Is it possible to import mfr files?
Is there any ways I can import the study setup from communicator files (.mfr) into my own synergy?
That way, i do not need to spend extra time to set up the same study.
5 REPLIES 5
bernor_mf
in reply to: aonotaka96
@aonotaka96
from what I know this is not possible to import .mfr file to Synergy.
It contains the study file .sdy, and resultfiles .o* , and aimed for Moldflow Communicator only.
When opening the .mfr in Moldflow Communicator, the mfr-file is unpacked to a temporary storage, such as:
C:\Users\user_id\AppData\Local\Temp\AMCx,
where x is a number.
In that folder the study file .sdy, and resultfiles .o* are temporarily stored, when viewing results.
I have even tried to import that .sdy to Synergy, but it crashed.
So, the Moldflow Communicator viewer files are locked for import to Synergy.
Even if your own files, they are locked.
This hard coded security probably has their reasons.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
PascalGosset
Hi simulators,
I agree with Berndt, it's not possible to import a MFR file in Synergy.
This could be also useful to import a mesh made by another person.
I wonder if I won't add a post in Ideas for that...
(no... I'm joking 😉 )
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
bernor_mf
@PascalGosset
Hi Pascal,
I would second that idea and kudos it. 😊
In the world of collaboration today, I find it a bit old-fashion to not having some options here.
Of course protecting data and proprietary information is important.
If having Moldflow Insight this should be possible.
Think of an option to lock or not lock the mfr for import to Synergy could be controlled when exporting from Communicator.
Either a tickbox, and a tickbox and a security code.
Basically as when sending a zip-file, locked by password or not locked.
Berndt
csegard
in reply to: bernor_mf
hello guys,
to go deeper on that idea, the use of shared views can be higly improved to have a use of shared datas (animation, results, ...) instead of using a software that need to be installed with the risk of version compatibilty, graphic issues,...
As you said Berndt, i would also vote for that 🙂
aonotaka96
Thank you everyone for sharing your experience/thoughts!
Hopefully we can have an option to make communicator files compatible with Synergy in the future update...
Technology Administrators
