- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear Altrusit,
I am working on my project in Injection Compression Molding. I have been using Moldflow to simulate two different materials with three different press compression speed in the compression settings to determine various qualities between these two materials. I have been facing some problems. Please help me out.
1. At first, I set the Fill+Pack setting as the automatic. Then I tried to change the parameters. For three different compression speed I got three different filling time in the automatic section. For the highest velocity profile the filling time is the least and the lowest velocity profile the filling time is the highest. Now I wanted to change the filling paramaters so that I want to get exactly same filling time for each profile. I took the highest filling time as reference and put the value in the Highest velocity profile as Injection time. Then I got the problem Short shot. What is the problem! Is not the filling time means the injection time in filling settings? Or do I assume it wrong or do I put the highest value which will not work here where i got the elast filling time as automatic one.
I want same filling time for all velocity profile. What should I do?
2. I found out that the percentage vollume filled during velocity pressure switch over is 125 percentage from the automatic parameters set. How can this be possible? Is it alright ? I put this value manually and it worked fine. Can you explain how this things happen?
3. There is no packing in Injection compression molding. In that regard, what should I do regarding the packing parametes?
4. In the compression setting switch to press force controll options, should I put from the start of compression? or any other option?
5. I have set all the parameters automatic and it worked fine. Now facing problems while changing the parameters manually. Specially in the filling and packing phase. Please help me out in this filling and packing phase problem. If I want same parameters specially same filling time and other aspects like 100 percent frozen layer fraction, what should I do in the filling and packing phase? How could I get the manual values from the preset data. Which values I need to consider.
These problems need to be solved. Please help me out. Specially @bernor_mf , I am really looking for your help as you helped me earlier. I am sending some screenshots for your consideration.
Best regards.
Riad
