- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Does anybody know a way how to force the Moldflow Insight solver writing results and then stop the currently running simulation?
I've got a simulation running on a linux cluster, which gives no intermediate results due to a bug in the solver.
According to the analysis log it should lead to a short shot, as the injection pressure has reached the machine limit after approximately 1.4 s (50 % of filling).
After 2.3 s 72 % are reached.
After 12 s there are still only 72.6 % filled and already 100.00 % frozen.
After 30 s the gates are closed, with only small changes in filling. The flow rate is around 0.01 cm³/s.
After 89s until 130 s there is still no end reached. The flow rate is around 0.001 cm³/s.
But if I cancel the simulation, I will have no results, so I won't see where the flow front hesitates and stagnates.
As this simulation iterates for several hours now, I would like to stop it, look at the results and prepare a better model with changed parameters.
Please use "accept as solution", so others may find solutions quickly. Also give kudos where suitable to further enhance these forums.
