How to run 2k analysis with 1st shot PBT and 2nd shot LSR material
How to run 2k analysis with 1st shot PBT and 2nd shot LSR material?
madhukeshwart
1. Are you performing 1st as injection molding and 2nd shot in reaction injection molding. then you can't
2. If both the shots injection molded. Get a UDB file for 2nd shot material for Liquid Silicone Rubber (LSR) .
Then perform as 2k molding simulation.
3. Perform the 1st has injection mold as a separate study as injection molding case & 2nd shot as insert molded with 1st shot part as a another study as reaction injection molding case
Refer this link for to simulate LSR part, consider first part as insert
https://knowledge.autodesk.com/support/moldflow-insight/troubleshooting/caas/sfdcarticles/sfdcarticl...
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
madhukeshwart
now you can
Injection-compression overmolding is extended in 2018  to support injection molding for the first shot and injection-compression molding for the second, overmolding shot. & Using  existing injection-compression overmolding analysis, you can simulate 2-shot overmolding where the first shot is injection-compression molding and the second shot is injection molding. This feature has been enhanced to support the reverse; injection molding for the first shot and injection-compression molding for the second, overmolding shot.
https://knowledge.autodesk.com/support/moldflow-insight/learn-explore/caas/CloudHelp/cloudhelp/2018/...
Madhukeshwar Talwar
09600060862
