How to reduce deflection?
Sanjay_paul
Message 1 of 29
Sanjay_paul
Hello everyone,
I have a part which is getting 7.9mm deflection.Is it possible to see how the deflection is reduced by adding cooling channel and rerunning the analysis. If yes, what are the steps after adding cooling channel to get better deflection result. I have previously run a simulation with and without cooling channel but there is no difference between the deflection results. Maybe I am doing it wrong way. Please comment your valuable opinion if you have faced the same problem.
Comparison with and without cooling channel
Regards
Sanjay Paul
Replies (28)
Message 21 of 29
madhukeshwart
@Sanjay_paul
1. You question shows ...deflection 7.9mm & Now it shows ...deflection 6.7 mm.
It clearly indicates..there is no much improvement.
https://forums.autodesk.com/t5/moldflow-insight-forum/how-to-reduce-deflection/m-p/7029298?lightbox-...
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
Message 22 of 29
madhukeshwart
Just follow the guidelines of mold flow
refer this link ... it helps
https://forums.autodesk.com/t5/moldflow-insight-forum/warpage-reduction/td-p/6838509
Madhukeshwar Talwar
09600060862
Message 23 of 29
mppkumar
Hi @Sanjay_paul
in your first post, you had only two gates, now you have three gates.
meaning you are improving your packing
earlier results you have shown with Moldflow insight latest results with Moldflow Advisor
why can't you perform the analysis in Moldflow insight and compare the results?
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
Message 24 of 29
Hi @Sanjay_paul
Good that we could see some improvements with the flow balancing condition. have you tried balancing the flow with earlier 2gate options...? also i could see you are using 6 injection cones on the gate entry why..? my suggestion again is please make sure that you are filling the part correct & then try other process optimization.
Message 25 of 29
Sanjay_paul
Hello Mr. Madhukeshwar,
Sorry for the misunderstanding. The deflection comparison you show in your post is look like same product but actually it is not. There is two different model.I forgot to mention it in the sabarinathan's reply. I am analyzing this new product recently and I didn't get time to analyze the previous one that's why I replied to sabarinathan's comment to show that flow balancing and changing ribs reduces deflection.
Thanks for sharing the link.
Regards
Sanjay Paul
Message 26 of 29
Sanjay_paul
Hi Pradeep Kumar,
Sorry for the misunderstanding.The comparison I have shown is a different model of door cap. Not the previous one. This post is only meant for sabarinathan's comment. At that time I did not have enough time that's why I used Moldflow adviser because Insight takes more to provide results.
Regards
Sanjay Paul
Message 27 of 29
Sanjay_paul
Hi sabarinathan,
Sorry for the misunderstanding. The deflection comparison i showed it is a different model of door cap.I forgot to mention it in your comment's reply. I am analyzing this new product recently and I didn't get time to analyze the previous one that's why I replied to your comment to show that flow balancing and changing ribs reduces deflection as you said. This comparison is only meant for you.
Regards
Sanjay Paul
Message 28 of 29
Hello Sanjay,
Options to reduce deformations
1.Increase the balance fill will help for controlling deformation.
2.Include cooling channels and the coolant temperature - optimize temperatures for controlling deformation.(Differential temperatures)
3.Look for adding stiffness element to the localized area in the high deformation region, if design permits
4. Work on the Windage model if still needs for controlling deformation
Its highly recommended to have insight in to the Plastic product design for a better/ controlled part and then look at alternatives.
Hope this helps.
Rajesh PV
Message 29 of 29
Sanjay_paul
Hello Mr. Rajesh,
Thanks for your suggestion. At 2nd point you advised me to add cooling channel. Is it possible to see in Moldflow insight  how deflection reduced due to cooling channel. If you have experienced something like that, please share some snaps with cooling and without cooling.
Regards
Paul
