Adding a filter to the material database for Medical or Automotive grades.
DlynamK6KTL
DlynamK6KTL
This is more of a suggestion than a question!
I think it would be very useful if Moldflow users could filter to only Medical, Food grade or Automotive approved material grades etc. This would remove the need to search extensively online whether the material chosen for the analysis is suitable for the application.
It would also be great as we would quickly learn the gold standard or shrinkage characterised grades from each sector and could steer our customers early on in the design process to use these grades for accurate Moldflow analysis.
Maybe it is something that could be considered for the next update!
David
madhukeshwart
@DlynamK6KTL
better post your request in Below given forum 'Mold flow Ideas'
https://forums.autodesk.com/t5/forums/postpage/board-id/91/load-autosave/true
Developer team may look into it and may implement if found useful
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
