Hi Abhijeet,
Please do the below setup,
Process setting wizard => Warpage setting (Page2)
Uncheck the "Use mesh aggregation and 2nd -order tetrahedral elements
Run the analysis. finally you will get the differential shrinkage results in the warpage.
Inba Sudhahar D
Mail: inba.oneway777@gmail.com
Phone: +91-9884929216
if the answer is accepted as a solution. Give Kudos as appropriate to further enhance these forums. Thank you! .....
