Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
How can I modify the ribbon menu???
4 REPLIES 4
508 Views, 4 Replies
I want to add my app on the ribbon menu. How can I modify the ribbon menu?
I know that I can assign macro to register. I want to modify the ribbon menu.
Anyone who knows please tell me!!!
4 REPLIES 4
nordhb
you can add commands to Quick Access Toolbar, the very top of UI window.
You can do that for a macro assigned to register as well.
If macro is assigned to register "1".
Right-click on "1" and select Add to Quick Access Toolbar
The circled "1" will now be in the Quick Access Toolbar.
When you want to remove it from Quick Access Toolbar:
Right-click on "1" in the Quick Access Toolbar and select Remove from Quick Access Toolbar
The Quick Access Toolbar can be shown above or below the Ribbon.
Default is above the Ribbon.
Hope this helps.
Berndt
Berndt Nordh
in reply to: nordhb
I think I would like to register My own custom Icon on the new ribbon.
It's my own VB app that was created through the API.
Please tell me....
in reply to: nordhb
Please tell me....
nordhb
first to recapture  the workflow to assign a macro to a command button:
1) In UI Synergy, tab Tools, click Assign Macro
(Note: Macros will only be available in first Synergy started)
2) Assign a macro to a command button, for example command button "1"
(if no commands assigned, the button is grayed out)
3) Right-click on "1" and select Add to Quick Access Toolbar
The icon will be a circled "1".
The look of this icon is as is, and cannot be changed.
Berndt
Berndt Nordh
