Hello Dinesh,
The internal edge length is referring to the edge length of the elements going through the thickness of your part. This can have an influence on how the simulation predicts flow of polymer - large edge length results in a longer distance between nodes used to calculate flow, ultimately leading to potential for things like flow pattern to not be captured correctly.
This edge length can be modified by experimenting with both the mesh's Global Edge Length and the Maximum allowed edgelength through the thickness. If you go into the "Generate Mesh" dialog, when meshing with 3D elements, then select the "Tetra" tab. Here, you can assign the 'Maximum allowed edge length through the thickness". To gain a better internal edge length ratio, I would suggest experimenting with these edge lengths.
I've included screenshots below of the internal elements of a rectangular part below. Both of these have the same global edge length, however I changed the "Maximum allowed edge length through the thickness" so as to better see what the effect is. The max internal edge length ratio for the 1mm mesh is 2.12, while the max internal edge length for the 0.25mm mesh is 1.97.
[Below: Maximum allowed edge length through the thickness = 1mm]
[Below: Maximum allowed edge length through the thickness = 0.25 mm]
I hope this helps!
Kristen Kilroy
_______________________________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
